Laravel aimeos HomePage
hi firends , i amnew in this and never worked on laravel before , i needto know how to change the homepage from welcome.blade.php to the file that refers to /list
how to change the home page to /list contents !
thanx all !
thanx all !
Re: Laravel aimeos HomePage
You can either redirect to the list page:
Or you can define the Aimeos list page to be the home page:
This forum is not suited for learning Laravel. If you need help to understand Laravel, there are much better forums out there, e.g. the laravel.io forum.
Route::get('', function () {
return redirect('list');
Route::group(config('shop.routes.default', ['middleware' => ['web']]), function() {
Route::match( array( 'GET', 'POST' ), '', array(
'as' => 'aimeos_shop_list',
'uses' => '\Aimeos\Shop\Controller\CatalogController@listAction'
