Bundled products and visibility
FedericoCánovas
Post by FedericoCánovas » 16 Jul 2018, 18:04
I would like to know how should I manage products visibility. Should I use status field?
For example:
I have bundled products and I don't want to sell children products individually. How can I hide them?
I know that products with status other than Enabled are not being showed on the front. Should I use one of the existing statuses? Should I create a new one for this purpose? Is there a better way to manage product visibility?
Re: Bundled products and visibility
Post by aimeos » 17 Jul 2018, 21:49
If you don't add a product to a category, customers won't be able to buy it separately.
