Error installing demo data on laravel package 2018.07
Hi, following the installation steps found this error when running: php artisan aimeos:setup --option=setup/default/demo:1
Please help,
Thanks...
Please help,
Thanks...
Re: Error installing demo data on laravel package 2018.07
Maybe this is a follow up problem of what you've described here:
laravel-package-f18/upgrading-aimeos-fr ... t1516.html
Thank you for your response,
However, even when problems can be related as you mentioned... I tried to install aimeos/laravel 2018.07 in a brand new laravel 5.6 installation with the ai-payment module and still getting this same error:
RuntimeException : No product for code "demo-article" found
at /home/antonio/aimeos201804/vendor/aimeos/aimeos-core/lib/mshoplib/setup/MShopAddDataAbstract.php:378
Thanks,
Thanks,
Can you post the complete output of the exception and the lines that have been outputed before?
Hi, the response is the image attached on the first thread.
Regards.
Regards.
That's not enough to getting closer to the problem. We need the full output of
