Typo3 CSV Import: Attribute Text and column double usage
Mathlin Comos
Post by Mathlin Comos » 20 Jul 2018, 13:33
using: Typo3 8.7.17 and Aimeos 18.7.0
is there a possibility to import attributes including their texts via the Scheduler?
My bet would've been the product import task but it doesn't add the attribute texts.
Something like:
0=attribute.text.languageid
1=attribute.text.type
2=attribute.text.content
or an external attribute importer would be perfect!
And is there a possibility to use columns of a CSV twice? e.g. I wan't to add two texts to a product: one short description in english and one long description in english.
Is there a possibility to use the column for the same language twice as id like:
0=text.languageid   #for english
1=text.type  #short description
2=text.content
##Add another Text
0=text.languageid   #use english once again
3=text.type    #this time for a long description
4=text.content
This would make the CSV file much smaller, cleaner and easier to adapt !
Thank you for your help.
Best regards
Re: Typo3 CSV Import: Attribute Text and column double usage
Post by aimeos » 21 Jul 2018, 08:16
Mathlin Comos wrote: is there a possibility to import attributes including their texts via the Scheduler?
There's no import for attribute texts/images/properties yet and yes, an attribute importer would by nice :-)
Mathlin Comos wrote: And is there a possibility to use columns of a CSV twice? e.g. I wan't to add two texts to a product: one short description in english and one long description in english.
Yes, that might work as you expect.
Mathlin Comos
Post by Mathlin Comos » 22 Jul 2018, 09:37
Hey,
thank you for your answer once again !
aimeos wrote: Yes, that might work as you expect.
Sadly, this does not work for me...
As soon as I try to map a column twice it imports nothing for this category (here languageid). Neither for the first text or for the second one
e.g.
CSV FILE:
"ProductCode","ProductLabel","ProductType","ProductStatus","TextType_1","Language","TextContent_1","TextType_2","TextContent_2"
"TestCSVImport","CSVImported","default",1,"short","en","This is short.","long","But this is a long description in english!"
Typoscript mapping
item {
0 = product.code
1= product.label
2 = product.type
3 = product.status
text {
#First text: short description
4= text.type
5= text.languageid
6 = text.content
#long description with the same language as before
7 = text.type
5=text.languageid #use english once again as a language
8 = text.content
With this config both texts won't have a language defined.
Mapping the languageid only one time (ligning out the mapping for the long description) will define the language for the first text; but not for the second one.
A solution to this would be including another column with the languageid for the second text, but as I already mentioned, the other way around would be much better and cleaner with a smaller CSV !
Best regards
Post by aimeos » 23 Jul 2018, 22:06
Yes, you are right. The column content is removed after being used the first time so it won't be available any more later on.
