Extend Price Item to create Price Lists
Hi there!
I need to extend Price Item from \vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Price\Item\Standard because I want to show different prices for a specific user. How could I do that ? My solution is to override the getValue() method from the Price\Standard class and check the user before return the price value, but how ?
Thank you in advance!
Re: Extend Price Item to create Price Lists
The customer group extension allows you to show products/prices/etc. to specific customers or customer groups:
https://aimeos.com/extensions/#c823
Thank you for you response, but I just need to override a simple method. There is no need of full extention.nos3 wrote:The customer group extension allows you to show products/prices/etc. to specific customers or customer groups:
Is there any other solution ?
Like always, you can extend the item to overwrite the methods you need and extend the manager to create your new own item in createItemBase() method.
