Product - Delete Multiple Products
mohal_04
Post by mohal_04 » 15 Aug 2018, 06:27
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.1.18
I need to delete more than 1 product from complex Aimeos DB schema. Can you please, guide me how I can do this by just one click? Or if there is any other method of deleting multiple products based on their ID or code?
Please, reply!
Thanks!
Re: Product - Delete Multiple Products
Post by aimeos » 15 Aug 2018, 15:31
You can easily delete multiple products by using deleteItems() of the product manager. This method accepts a list of product IDs.
If you want to clean up everything that is associated to the products (categories, images, prices, texts), you can use this code:
$productItems = [...];
$catalogListManager = \Aimeos\MShop\Factory::createManager( $context, 'catalog/lists' );
$search = $catalogListManager->createSearch()->setSlice( 0, 0x7fffffff );
$expr = [
    $search->compare( '==', 'catalog.lists.refid', array_keys( $productItems ) ),
    $search->compare( '==', 'catalog.lists.domain', 'product' ),
$search->setConditions( $search->combine( '&&', $expr ) );
$listItems = $catalogListManager->searchItems( $search );
$catalogListManager->deleteItems( array_keys( $listItems ) );
$productManager = \Aimeos\MShop\Factory::createManager( $context, 'product' );
foreach( $productItems as $item ) {
    $item->deleteListItems( $item->getListItems( ['media', 'price', 'text'], null, null, false ), true );
    $productManager->saveItem( $item ); // deletes are referenced media, price and text items
$productManager->deleteItems( array_keys( $productItems ) );
Beware: This does only work since 2018.07 (current stable version)
mohal_04
Post by mohal_04 » 16 Aug 2018, 05:16
aimeos wrote:You can easily delete multiple products by using deleteItems() of the product manager. This method accepts a list of product IDs.
$expr = [
Thanks for the help! It may take me some time to understand all this but hopefully, I shall make it happen. I would suggest though, if you guys can give an option in future release to delete more than one product on Product List page then it would be great.
Thanks!
Post by aimeos » 16 Aug 2018, 08:14
mohal_04
Post by mohal_04 » 16 Aug 2018, 08:44
aimeos wrote:Yes, it's already on the list: https://github.com/aimeos/ai-admin-jqadm/issues/23
Great!
