New Laravel Installation
archmaster
Post by archmaster » 30 Aug 2018, 02:56
Local Installation
Laravel 5.4.36
"aimeos/aimeos-laravel": "~2018.07"
Apache PHP 5.6.25
Windows 10
I am following the directions as posted in github: https://github.com/aimeos/aimeos-larave ... el-package for a fresh installation of aimeos, and all is going well until I get to the step:
, where I get the following:
In Simple.php line 97:
An exception occurred while executing 'ALTER TABLE users_address ADD CONSTRAINT fk_lvuad_pid FOREIGN KEY (parentid) REFERENCES users (id) ON UPDATE CASCADE ON DELETE CASCADE':
SQLSTATE[HY000]: General error: 1215 Cannot add foreign key constraint
Since that stops the batch execution, the tables remain empty, no demo data is shown.
Then when visiting the link: http://127.0.0.1:8000/index.php/list, I get the following:
(1/1) Exception
No item found for conditions: Array
[locale.site.code] => default
I have deleted the users_address table, as suggested in: post6396.html#p6344, to no avail, the same exception keeps showing up.
Any help will be greatly appreciated.
Re: New Laravel Installation
Post by aimeos » 30 Aug 2018, 07:04
Can you post the output of
SHOW CREATE TABLE users
and
SHOW CREATE TABLE users_address
archmaster
Post by archmaster » 30 Aug 2018, 18:22
Of course. This is the output:
Local Databases/ http://localhost/phpmyadmin/server_sql. ... 59e25817c9
Su consulta se ejecutó con éxito.
SHOW CREATE TABLE myshop.users
users CREATE TABLE `users` (
 `id` int(11) NOT NULL AUTO_INCREMENT,
 `name` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
 `email` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
 `password` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
 `remember_token` varchar(100) COLLATE utf8_unicode_ci DEFAULT NULL,
 `created_at` datetime NOT NULL,
 `updated_at` datetime NOT NULL,
 `superuser` smallint(6) NOT NULL DEFAULT '0',
 `siteid` int(11) DEFAULT NULL,
 `label` varchar(255) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `salutation` varchar(8) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `company` varchar(100) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `vatid` varchar(32) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `title` varchar(64) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `firstname` varchar(64) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `lastname` varchar(64) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `address1` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `address2` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `address3` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `postal` varchar(16) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `city` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `state` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `langid` varchar(5) COLLATE utf8_unicode_ci DEFAULT NULL,
 `countryid` char(2) COLLATE utf8_unicode_ci DEFAULT NULL,
 `telephone` varchar(32) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `telefax` varchar(32) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `website` varchar(255) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 `longitude` decimal(8,6) DEFAULT NULL,
 `latitude` decimal(8,6) DEFAULT NULL,
 `birthday` date DEFAULT NULL,
 `vdate` date DEFAULT NULL,
 `status` smallint(6) NOT NULL DEFAULT '1',
 `editor` varchar(255) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
 PRIMARY KEY (`id`),
 UNIQUE KEY `users_email_unique` (`email`),
 KEY `idx_lvusr_langid` (`langid`),
 KEY `idx_lvusr_last_first` (`lastname`,`firstname`),
 KEY `idx_lvusr_post_addr1` (`postal`,`address1`),
 KEY `idx_lvusr_post_city` (`postal`,`city`),
 KEY `idx_lvusr_lastname` (`lastname`),
 KEY `idx_lvusr_address1` (`address1`),
 KEY `idx_lvusr_city` (`city`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
________
SHOW CREATE TABLE myshop.users_address
users_address CREATE TABLE `users_address` (
 `parentid` int(11) NOT NULL,
 `siteid` int(11) NOT NULL,
 `company` varchar(100) COLLATE utf8_unicode_ci NOT NULL,
 `vatid` varchar(32) COLLATE utf8_unicode_ci NOT NULL,
 `salutation` varchar(8) COLLATE utf8_unicode_ci NOT NULL,
 `title` varchar(64) COLLATE utf8_unicode_ci NOT NULL,
 `firstname` varchar(64) COLLATE utf8_unicode_ci NOT NULL,
 `lastname` varchar(64) COLLATE utf8_unicode_ci NOT NULL,
 `address1` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
 `address2` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
 `address3` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
 `postal` varchar(16) COLLATE utf8_unicode_ci NOT NULL,
 `city` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
 `state` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
 `telephone` varchar(32) COLLATE utf8_unicode_ci NOT NULL,
 `telefax` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
 `website` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
 `flag` int(11) NOT NULL,
 `pos` smallint(6) NOT NULL,
 `mtime` datetime NOT NULL,
 `ctime` datetime NOT NULL,
 `editor` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
 PRIMARY KEY (`id`),
 KEY `idx_lvuad_pid` (`parentid`),
 KEY `idx_lvuad_last_first` (`lastname`,`firstname`),
 KEY `idx_lvuad_post_addr1` (`postal`,`address1`),
 KEY `idx_lvuad_post_city` (`postal`,`city`),
 KEY `idx_lvuad_address1` (`address1`),
 KEY `idx_lvuad_city` (`city`),
 KEY `idx_lvuad_email` (`email`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
Hope it´s helpful.
Post by aimeos » 30 Aug 2018, 21:02
Your table definition seems to be OK, user.id and users_address.parentid are of the same type and length. Do you have any parent IDs in users_address that are not present in the users table any more?
archmaster
Post by archmaster » 30 Aug 2018, 22:42
No. I don´t think so. It is a fresh installation and I have not done any modifications. Ultimately all I am doing is running the script:
I have repeated the whole process several times from the start, always getting the same result.
mohal_04
Post by mohal_04 » 31 Aug 2018, 06:22
Why are you not installing it on Laravel 5.6?
archmaster
Post by archmaster » 31 Aug 2018, 14:37
Well, I am following the instructions to the letter, so I am using this line as is, for the laravel installation:
composer create-project --prefer-dist laravel/laravel myshop
archmaster
Post by archmaster » 01 Sep 2018, 02:21
So I updated my development environment, like so:
Local Installation
Laravel 5.6.35
Apache PHP 7.2.9
Windows 10
But still got the exact same result. Any thoughts??
Post by aimeos » 01 Sep 2018, 13:54
Your "users" table is of type "MyISAM" instead of "InnoDB" and foreign key constraints only work with "InnoDB". This might be caused by a database server default setting. Which MySQL database version do you use?
Change the engine of the users table to "InnoDB", then it will work.
archmaster
Post by archmaster » 01 Sep 2018, 17:47
Your are right. It´s working perfectly now!
Thanks a lot guys!
