Invalid Catalog Lines
jramirezgranada
Post by jramirezgranada » 30 Aug 2018, 21:32
Hi there;
I'm trying to import categories from magento to aimeos, when i run the command i got this error
php artisan aimeos:jobs catalog/import/csv
Executing the Aimeos jobs for "default"
Invalid catalog lines in "storage/csv": 132/132#0 /home/vagrant/sync/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(69): Aimeos\Controller\Jobs\Catalog\Import\Csv\Standard->run()
#1 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), 'catalog/import/...')
my shop.php config
'controller' => [
        'jobs' => [
            'catalog' => [
                'import' => [
                    'csv' => [
                        'location' => 'storage/csv',
                        'skip-lines' => 1
can you help me with that
Jorge A Ramirez
System Engineer
PHP Developer
mohal_04
Re: Invalid Catalog Lines
Post by mohal_04 » 31 Aug 2018, 06:26
jramirezgranada wrote:Hi there;
my shop.php config
'controller' => [
        'jobs' => [
            'catalog' => [
                'import' => [
                    'csv' => [
                        'skip-lines' => 1
How about change 'location' key:
'location' => base_path('storage/tmp/product')
Use 'base_path'.
And are you following the correct CSV format?
Thanks!
Post by aimeos » 01 Sep 2018, 13:39
When errors occur during the import they are logged and you should be able to see them in the log panel.
