Checkout - Credit Card
mohal_04
Post by mohal_04 » 13 Sep 2018, 14:31
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.1.18
I want to setup Credit Card checkout. Is this option already available? If yes then from where I can enable it. If no then how I can integrate Credit Card checkout?
Please, reply ASAP!
Thanks!
Re: Checkout - Credit Card
Post by aimeos » 13 Sep 2018, 19:24
You need a payment service provider which handles credit card payments. The Omnipay integration supports a lot of them. Storing credit card data locally is forbidden and not supported!
mohal_04
Post by mohal_04 » 14 Sep 2018, 06:22
aimeos wrote:You need a payment service provider which handles credit card payments. The Omnipay integration supports a lot of them. Storing credit card data locally is forbidden and not supported!
Thanks for your reply!
So, is Omnipay already integrated in Aimeos 2018.04? If yes then from where I can access it?
Please reply!
Thanks!
Post by aimeos » 15 Sep 2018, 09:10
You need the ai-payments extension. A few payment drivers are documented here:
https://aimeos.org/docs/User_Manual/Adm ... rvice_list
