Safest way to reset ORDER TABLE
I made some tests on Aimeos and I would like now to empty and reset the AI order tables ONLY (I would like to keep my users and products)!
Is there a command that allow that or do I need to manually clean it in the db?
Thank you very much,
sbn
sbn
Re: Safest way to reset ORDER TABLE
You have to manually truncate the mshop_order* tables
That was my plan... but I wanted to be sure
Thank you very much !
