Add to cart - products purchased jointly
Dear master,
We need to add custom functionality for product detail:
- We will show the related products
- For each of them, we have checkbox that user can check or un-check
- There is button add all to cart , when user click on it, the selected items will be added to cart first. When user click on Add to cart, the current product will be added to cart later.
Could you please let me know if we can or can not reach it? How is the solution?
Thank all,
Thank all,
Re: Add to cart - products purchased jointly
That's relatively easy to implement because the related products (type "suggestion" or "bought-together") are already displayed at the detail page if there are any. You only have to add the buttons to add them to the basket (one or all of them).
To implement this , you have to extend the products partial (https://github.com/aimeos/ai-client-htm ... andard.php), move the <form> tag outside into the product detail template (https://github.com/aimeos/ai-client-htm ... d.php#L502) and add a "add all to cart" button there.
Please note that you also need to use this patch from dev-master:
https://github.com/aimeos/ai-client-htm ... bbbbea85e1
