User xxx has more than 'max_user_connections' error
I read the LOG of my server errors and I see many : "User xxx has more than 'max_user_connections' active connections" errors on various Aimeos Requests (like createsearch, finditem, etc.). It seems to be often different ones.
I'm currently trying to detect how and when those errors happen exactly.
I'm wondering if my server config is not powerful enough for Aimeos or if I made something wrong... maybe I should manually close some connections at some point or on some errors.
Do you have any recommendations or experience about this problem?
Are sometimes, Aimeos DB requests closed manually ?
Thank you very much !
sbn
sbn
Re: User xxx has more than 'max_user_connections' error
Aimeos uses max three connections per request (resource/db/limit setting). If the connections aren't closed by the database server, do you have persistant connections enabled?
