Missing Product Images From Localhost as :8000 is missing.
Golfmad
Post by Golfmad » 01 Nov 2018, 11:46
Installed locally and have it up and running, however I've hit a bit of a stumbling block as locally uploaded images are not showing in admin or frontend. Given the folders the correct permissions and the image is actually being uploaded. I have noticed that when I look at the image URL it is looking for
However it should be looking for
Is there a setting where I can set it to look for the missing port :8000 instead of leaving it out?
Re: Missing Product Images From Localhost as :8000 is missin
Post by aimeos » 02 Nov 2018, 09:19
Seems like you've using Laravel. Adapt the APP_URL variable in your .env file and add ":8000" for your port
Golfmad
Post by Golfmad » 07 Nov 2018, 10:37
Hi, thank you that worked.
