No value for key "item" found in Standard.php:119
Hello
I have added some product using product upload and now if I try to update the product and then change is not saved in the database and I am getting this error No value for key "item" found, /var/www/html/interloper-laravel/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php:119
I also attach the screenshot that error i am getting
So please anyone help how to fixed and resolve this error
- screenshot-localhost-8000-2018.11.05-15-26-31.png (123.04 KiB) Viewed 3028 times
Re: No value for key "item" found in Standard.php:119
Please have a look into the "Log" panel and look for the stack trace for this error. There you can see in which template the problem occurs so you can try to fix the problem.
