Is this an accepted way of retrieving data?
Golfmad
Post by Golfmad » 08 Nov 2018, 12:23
Hi
New to Laravel and this framework, I just wanted to check to see if this is an accepted/recommended method of getting data about "items". For example I wanted to retrieve the short description about a category so I did the following.
//var_dump($catItem->getRefItems( 'text' ))
$text_for_category =  $catItem->getRefItems( 'text' );
foreach( $text_for_category as $text ) {
	if($text->getTypeName() == "Short description"){
		echo $text->getContent();
As stated, not sure if this is the best approach (perhaps by doing it this way I am missing out on features) but it does seem to output my expected data.
Re: Is this an accepted way of retrieving data?
Post by aimeos » 09 Nov 2018, 20:47
It's much easier. You only have to use this:
$catItem->getRefItems( 'text', 'short', 'default' )
"short" is the text type for the catalog domain you have to create and use for category short descriptions. "default" is the list type in the mshop_catalog_list table
