Get parent product
Get parent product
Hi there;
I have a selection products with 3 variants product, is there a way to know what is the parent product of those variants ?
Jorge A Ramirez
System Engineer
PHP Developer
Jorge A Ramirez
System Engineer
PHP Developer
Re: Get parent product
You can search for the parent product in 2018.10 using:
$manager = \Aimeos\MShop\Factory::createManager( $context, 'product' );
$criteria = $manager->createSearch();
$func = $criteria->createFunction( 'product:has', ['product', 'default', '<prodid>'] );
$criteria->setConditions( $criteria->compare( '!=', $func, null ) );
$items = $manager->searchItems( $criteria );
Does it work in 2017.07 ?
Jorge A Ramirez
System Engineer
PHP Developer
Jorge A Ramirez
System Engineer
PHP Developer
No, but you should update nevertheless because 2018.07 isn't supported any more 2018.10 is the new LTS version.
Sorry 2018.07, it does it work in that version?
Jorge A Ramirez
System Engineer
PHP Developer
Jorge A Ramirez
System Engineer
PHP Developer
Also no. It's new in 2018.10 and you should upgrade too. The upgrade between that versions should be smooth.
