Add own JavaScript function to AimeosCatalogDetail.init()
Moritz
Post by Moritz » 30 Nov 2018, 15:44
I've added a JavaScript file via TypoScript.
Now I want to call my own function additionally to the init() function in AimeosCatalogDetail.
For that I read your documentation here: https://aimeos.org/docs/Developers/Them ... ing_themes and copy your example:
    AimeosCatalogDetail.init = (function(fcn) {
        var self = this;
        return function() {
            fcn();
            self.setupYourMethod();
    })(AimeosCatalogDetail.init);
That doesn't work. My debugger displays following error message: "TypeError: this.setupServiceSlider is not a function".
I think because of the decorator pattern the keyword "this" in AimeosCatalogDetail.init() has now a wrong context.
Can you help me with a working example please?
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
Aimeos web shop 22.10.4-pre3
Re: Add own JavaScript function to AimeosCatalogDetail.init(
Post by aimeos » 03 Dec 2018, 09:16
Can you post your code?
Moritz
Post by Moritz » 03 Dec 2018, 10:03
I only have the following code from your documentation:
And I get this error message:
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
Post by aimeos » 03 Dec 2018, 12:59
Did you add the JS code after the aimeos-detail.js file is loaded?
Moritz
Post by Moritz » 03 Dec 2018, 13:33
Yes, my JS file is the last line inside my <body> Tag.
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
Post by aimeos » 04 Dec 2018, 15:23
This does work properly and the docs have been adapted:
	AimeosCatalogDetail.setupYourMethod = function() {
		console.log( 'test' );
    AimeosCatalogDetail.init = (function(obj) {
		init = AimeosCatalogDetail.init.bind(obj);
		return function() {
			obj.setupYourMethod();
			init();
    })(AimeosCatalogDetail);
Moritz
Post by Moritz » 04 Dec 2018, 17:00
Thank you for this example and your help!
I've found another solution as well:
    var self = this;
    return function() {
        fcn.call(AimeosCatalogDetail);
With .call(AimeosCatalogDetail) I set the context correctly back to AimeosCatalogDetail.
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
