Access product properties in basket
Dear aimeos Team
How can I access product properties inside the basket view?
As I can see the properties values are not available inside the array the $this->summaryBasket->getProducts() is returning
in the file /html/templates/common/summary/detail-standard.php
Or as an alternative is it easier to access a «Article specific configuration options» (Setup at the basic tab of a product / key/value pair ) inside the basket?
I just need a value that I can use specific for every product inside the basket (and also on the product detail page).
I'm using Typo3 8.7.20 with aimeos 18.10.2 / PHP 7.2.1 / Apache (Local on Mac OS with MAMP).
Thank you!
Thank you!
Re: Access product properties in basket
If you only need a single, specific property, you can add it to the basket product by configuring the "PropertyAdd" basket plugin: https://github.com/aimeos/aimeos-core/b ... dd.php#L16
Thank you for your fast support!
Can you please tell me more about how I can configure the PropertyAdd basket plugin...
As I can see the file PropertyAdd.php is already part of your aimeos core. At the top of the file I can see the example configuration. Where do I have to add this configuration - by TypoScript Setup?
Example configuration:
* - product.property.parentid: ['length', 'width', 'heigth', 'weigth']
The configuration needs to be added to the config section of the basket plugin in the admin interface
I could set up the PropertyAdd Plugin now. The property I want to add to the basket has the code 'pp-dim-width' in my case. I tried different configurations but no one is working. Depending on my setup I get the following error:
Argument 3 passed to Aimeos\MShop\Plugin\Provider\Order\PropertyAdd::addAttributes() must be of the type array, string given,
Or I just get no error message but I cant see the given value at the basket product object anyway.
To test if I get the value I need inside the basket I just use at the file detail-standard.php and then search for my pp-dim-width attribute. But I cant see it there.
Can you please tell me how exactly the plugin configuration must look like?
Thank you.
<?php var_dump($product); ?>
Thank you.
- aimeos-add-product-property-to-basket.png (68.44 KiB) Viewed 2353 times
Think, the value must be
as it's interpreted as JSON. Can you try?
["pp-dim-width"]
I tried out different configurations / different strings to pass the value to the basket. But without success. I can not see the value in the product object inside the basket. Some of the JSON-string values I entered directly into the database, because the backend did not accept my values (the save button does not react - without error message).
Now I did a completely other solution with JavaScript and LocalStorage outside aimeos. This is working for me because I don't really need the basket in this project (we dont need the order part on this project - instead we have a favourite / collection-box function). But for a future project, solving this issues here may become important again...
A rewrite of the plugin is on the list: https://github.com/aimeos/aimeos-core/issues/133
