Using several domains with multishop.
Hello! First of all, i would like to say thank you for your help in my previous topics.
Now i`m working with multishop and configured a few test shops using one Aimeos instance.
At this moment their URLs are looking like mydomain.com/shop1/list and mydomain.com/shop2/list.
Please tell me, is it possible to use different independent domains for each shop? For example shop1.com for mydomain.com/shop1/list and shop2.com for mydomain.com/shop2/list.
Thank you!
Thank you!
Re: Using several domains with multishop.
Not sure because this is totally dependent on what Laravel can do. Sub-domain are possible according to the Laravel docs: https://laravel.com/docs/5.7/routing#ro ... in-routing
