Overwriting templates
KevinPopkorn
Post by KevinPopkorn » 04 Feb 2019, 08:18
I'm not sure if we're getting the way we have to overwrite templates correctly, would be nice if someone could shed some light on this :) We are listing the templates we are overwriting in the shop config "client, html, <component>" array structure, but it seems to be a bit unclear on how we have to build up the array to overwrite the correct template.
For instance right now we are trying to overwrite the template:
ai-client-html/client/html/templates/catalog/filter/tree-standard.php
Which is the filter category list. How do we need to build up the array structure?
We have tried things like:
   'client' => [
        'html' => [
                'filter'  => [
                    'tree'   => [
                        'standard' => [
                            'template-body' => resource_path('views/catalog/filter/tree-body-standard.php'),
                        'partials' =>
                            'tree' => [
                                'template-body' => resource_path('views/catalog/filter/tree-standard.blade.php')
But to no success, or a serious amount of hit and miss :) Can someone ellaborate a little on how the structure is supposed to be set up? We have successfully overwritten other templates with trial and error but with partials it seems to be a bit unclear naming wise.
Re: Overwriting templates
Post by aimeos » 04 Feb 2019, 09:51
Youve' missed the "catalog" part, it's 'client/html/catalog/filter/tree/standard/template-body' and 'client/html/catalog/filter/partials/tree':
- https://github.com/aimeos/ai-client-htm ... rd.php#L98
- https://github.com/aimeos/ai-client-htm ... rd.php#L80
But you don't have to overwrite the configuration. If you copy the template you want to overwrite from:
./ext/ai-client-html/client/html/templates/catalog/filter/tree-body-standard.php
to
./ext/<yourext>/client/html/templates/catalog/filter/tree-body-standard.php
it will be found automatically and used instead of the original one :-)
KevinPopkorn
Post by KevinPopkorn » 04 Feb 2019, 10:01
Hi, thanks for the info but I apparently missed Catalog in the copy paste, it is there in our code :)
We tried adding our own ext but it still didn't seem to want to overwrite the templates, that's why we went with the configuration method instead.
Edit: We did try to use blade templates, not sure if that changes anything?
Post by aimeos » 04 Feb 2019, 10:37
For Blade templates, you need the configuration and the extension of the Blade templates must be ".blade.php" instead of only ".php"
KevinPopkorn
Post by KevinPopkorn » 04 Feb 2019, 11:52
Yes, have the .blade.php but it still refuses to overwrite the partial.
We have it working without blade, but if we try to change it to a blade it doesn't take it.
Edit: Seems there's some special magic going on as it seems to work for my colleague and on production environment but not on my machine :roll:
KevinPopkorn
Post by KevinPopkorn » 05 Feb 2019, 14:14
This seems like a different issue entirely, my templates seem hard stuck in cache, eventhough I cleared it all through aimeos:cache etc. I don't see my colleague's adjustments that are there in files on my localhost in the rendered page.
KevinPopkorn
Post by KevinPopkorn » 05 Feb 2019, 14:28
Update: This command saved the day :)
php artisan optimize:clear
Seems everything was stuck in cache.
