Add To Basket Functionality From Product List Page.
We Want This Functionality That When We Click On Specific Product "Add To Cart" Button Form Category Product List .
That Item Can Be Added To Basket.
For Reference:
http://prntscr.com/mis2ye
For Reference:
Re: Add To Basket Functionality From Product List Page.
Use this configuration option and don't forget to add the option for the mentioned domains:
https://aimeos.org/docs/Configuration/C ... basket-add
- parmonov98
Admin! I dunno why, somehow your answers don't kick my head.aimeos wrote: ↑09 Feb 2019, 14:08 Use this configuration option and don't forget to add the option for the mentioned domains:
Can you tell me how to use the basket-add step-by-step?
I mean, where to add this line, and what to change on what components/templates?
Nothing, it's only a configuration option you have to set in your ./config/shop.php:
'client' => [
'html' => [
'catalog' => [
'lists' => [
'basket-add' => 1
'domains' => array( 'attribute', 'media', 'price', 'product', 'text' )
