Remove Coupon on Basket
tenkraD
Post by tenkraD » 14 Feb 2019, 16:46
Hi all, is it possible by configuration supparts to remove the coupon part on basket standard.
# https://aimeos.org/docs/Configuration/Core/client/html/basket/standard/standard/subparts
## client/html/basket/standard/default/subparts
plugin.tx_aimeos.settings.client.html.basket.standard.standard.subparts{
   0 = detail
# https://aimeos.org/docs/Configuration/Core/client/html/basket/mini/standard/subparts
# client/html/basket/mini/standard/subparts
plugin.tx_aimeos.settings.client.html.basket.mini.standard.subparts{
   0 = detail
The above Typoscript is not working. I get an Error: Class "\Aimeos\Client\Html\Basket\Mini\Detail\Standard" not available.
Many Thanks
Re: Remove Coupon on Basket
Post by aimeos » 15 Feb 2019, 13:43
We've reduced the number of subparts in 2017.01 because it complicated frontend development. To remove the coupon part, copy the basket standard template and remove the HTML code there:
https://github.com/aimeos/ai-client-htm ... rd.php#L78
