Localization problems
We have created a simple localization management system in Laravel by creating a localization middleware like:
Http/Middleware/Localization.php
Inside there's some simple code to set the locale as Laravel's documentation recommends it.
It takes the first segment of the URI and tries to match either 'en' or 'it' and fallback to 'it' if it cannot match 'en'
Laravel part seems to work ok with it.
The problem that we're having seems to be on one of the the checkout steps
More precisely, the one that has the URI like:
/en/default/checkout/delivery
After passing this steps the shopping cart seems to be empty or not found
If we repeat the checkout process, but in italian language, so this step has the URI like:
/it/default/checkout/delivery
Everything seems to be ok.
Putting some debugging code like:
In ext/ai-controller-frontend/controller/frontend/src/Controller/Frontend/Basket/Base.php
Seems to give back something like:
Laravel locale is: it
Even though the page has the first URI prefix as /en'
So my questions are:
1. Is Aimeos interfering with the locale by Laravel's Localization middleware ?
2. Any idea why Laravel's locale is changed when there's a single setLocale function put in the Localization middleware
3. Is it possible to set the Aimeos locale from Laravel's Localization middleware in a somewhat similar way that we do it for Laravel with:
4. Does the basket have its own independent locale, if yes, how do we set that ?
5. Can the language be changed independently of the current site or the language is tied in any way with one site ?
We use:
Laravel 5.4
Aimeos 2017.4 plus Market place extension
PHP 7.2.12
<?php
namespace App\Http\Middleware;
use Closure;
class Localization
* Handle an incoming request.
* @param \Illuminate\Http\Request $request
* @param \Closure $next
* @return mixed
public function handle($request, Closure $next)
$language_code = \Request::segment(1);
$locale = '';
switch ($language_code) {
case 'en':
$locale = 'en';
break;
case 'it':
$locale = 'it';
break;
default:
$locale = 'it';
// 1. Set Laravel's locale
\App::setLocale($locale);
// 2. Set Carbon's locale
//\Carbon\Carbon::setLocale($locale); // Not enabled at the moment
return $next($request);
\Log::debug("Laravel locale is: " . app()->getLocale());
We use:
Laravel 5.4
PHP 7.2.12
Re: Localization problems
The language in Aimeos frontend should be always the one that's in the URL provided you've set the prefix for Aimeos routes accordingl ('prefix' => '{locale}/{site}' in your case):
- https://github.com/aimeos/aimeos-larave ... hop.php#L5
- https://aimeos.org/docs/Laravel/Configu ... he_routing
- https://aimeos.org/docs/Laravel/Add_loc ... tor#Routes
The languages must be also enabled in the Locale -> Language tab of the admin interface and there must be enabled site/language/currency combinations in the Locale tab.
The basket has items in the site/language/currency combination that has been used when adding the product to the basket. If the combination changes it tries to migrate the basket content to the new combination be refetching the items if possible: https://github.com/aimeos/ai-controller ... e.php#L133
That should all apply to your old (unsupported) version as well.
