Add product into basket
I'm new to aimeos and have some issue.
I have products into my website that i'm uploading to the aimeos database from a remote server throw a csv file.
Now i want to add a product to the basket from the front end and what it does not work.
It always says "Basket empty"
This is my form :
Please can some one help?
This is my form :
<form method="POST" action="{{url('/basket')}}" id="formbasket" name="formbasket">
<input type="hidden" name="_token" id="csrf-token" value="{{ Session::token() }}" />
<div class="addbasket">
<div class="input-group">
<input type="hidden" name="b_action" value="add">
<input type="hidden" name="b_prod[0][prodid]" value="{{$data['product_id']}}">
<input type="hidden" name="b_prod[0][quantity]" value="1">
<button class="btn btn-primary btn-lg" type="submit" value="">
Add to basket
</button>
</div>
</div>
</form>
Re: Add product into basket
Problem solved,
I had to add a categorie to each product
