Compare/SQL.php
jramirezgranada
Compare/SQL.php
Post by jramirezgranada » 22 Feb 2019, 17:52
Hi there;
I need to extend /vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Criteria/Expression/Compare/SQL.php what is the best way to do that.
I need this, in the tables views in admin when you search a text it is camel case, so i want to add a new operator in that file to create a searc non-camel-case.
Jorge A Ramirez
System Engineer
PHP Developer
Re: Compare/SQL.php
Post by aimeos » 23 Feb 2019, 17:32
Which database are you using? If it's MySQL, the simplest way to case insensitive comparison is using "utf8mb4_unicode_ci" as collation in ./config/database.php
jramirezgranada
Re: Compare/SQL.php
Post by jramirezgranada » 23 Feb 2019, 18:18
I'm using postgres.
Thks
Jorge A Ramirez
System Engineer
PHP Developer
Re: Compare/SQL.php
Post by aimeos » 24 Feb 2019, 16:17
You can overwrite the createSearch() method in every manager where you need the alternative criteria implementation:
https://github.com/aimeos/aimeos-core/b ... se.php#L74
Unfortunately, it's not possible to replace the base class to provide an alternative criteria implementation for all classes inheriting from that one.
david22
Re: Compare/SQL.php
Post by david22 » 27 Feb 2019, 19:44
Will you please tell me, how to create a MySQL Database Using MySQLi and PDO?
As I am a beginner, I have tried to run the code but it did not work.
<?php
//Make the database connection.
db_connect() or die('Unable to connect to database server!');
function db_connect($server = 'localhost', $username = 'root', $password = '', $database = 'hct_db', $link = 'db_link') {
global $$link;
$$link = mysql_connect($server, $username, $password);
if ($$link) mysql_select_db($database);
return $$link;
//Function to handle database errors.
function db_error($query, $errno, $error) {
die('Cannot connect to database');
//Function to query the database.
function db_query($query, $link = 'db_link') {
global $$link;
$result = mysql_query($query, $$link) or db_error($query, mysql_errno(), mysql_error());
return $result;
//Get a row from the database query
function db_fetch_array($db_query) {
return mysql_fetch_array($db_query, MYSQL_ASSOC);
