how to setup customer and admin account
Please give me step by step guid that i which .
customer can register and login to their account and customer can only see their details and order details
and the second thing is i want to redirect the customer to their dashboard means if admin is login it should go to admin dashboard and if simple customer in login then the customer should go to thier pannel.
Thanks.
Thanks.
Re: how to setup customer and admin account
Customer and admin login are two separate routes ("myaccount" and "admin") and they will be forwarded to their profile resp. dashboard after login. Login is handled by Laravel (https://github.com/aimeos/aimeos-laravel#admin) and it also sets up authentication for customers.
aimeos wrote:Customer and admin login are two separate routes ("myaccount" and "admin") and they will be forwarded to their profile resp. dashboard after login. Login is handled by Laravel (https://github.com/aimeos/aimeos-laravel#admin) and it also sets up authentication for customers.
with which condition i can check that admin is logged in or customer is logged in.
Thanks.
