Problems with resources in admin dashboard
FAlberto
Post by FAlberto » 13 Mar 2019, 19:30
Hi!
I'm new in Aimeos and I added this package to my website written in SlimPHP.
Everything was ok until that in the admin dashboard don't charged some resources.
Specifically when I go to the /admin route, there are a call with the OPTIONS method to /admin/default/jsonadm with the 404 code.
I don't know how to fix this. Please anyone can help me?
Slim ^3.0, aimeos-slim ~2017.07, Windows 10
https://imgur.com/a/HOHXWp2
Re: Problems with resources in admin dashboard
Post by aimeos » 13 Mar 2019, 20:03
Which version of Slim and Aimeos do you use?
FAlberto
Post by FAlberto » 14 Mar 2019, 13:08
From composer.json:
"slim/slim": "^3.0" ,
"aimeos/aimeos-slim": "~2017.07"
I update the aimeos-slim version to 2018.10 and the same issue is ocurring.
I followed the instructions on the https://github.com/aimeos/aimeos-slim
Thanks in advance.
Post by aimeos » 15 Mar 2019, 09:44
Does one of your routes collide with the Aimeos ones? We've checked and in a blank Slim installation the OPTIONS request to the JsonAdm API works without problems. Another problem could be that your web server doesn't allow OPTIONS requests for some reason (e.g. configuration).
FAlberto
Post by FAlberto » 15 Mar 2019, 13:07
Very thanks, the problem is with one middleware that I use in my routes.php, the TrailingSlash middleware, but i don't know exactly why, I commented this middleware and the problem is solved...
Really thanks :D.
