CSV product import: Downloads
Is there a possibility to attach download files to a product when importing a CSV?
For images I can use 'media.url' and the relative path to it.
I didn't find anything similar for download files...
Grettings
Moritz
Grettings
Moritz
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
Aimeos web shop 22.10.4-pre3
PHP 7.4.30
Typo3 v11.5.21 LTS
Re: CSV product import: Downloads
It's possible but requires a bit more understanding how Aimeos saves downloads internally. They are "hidden" attributes of type "download" with the relative URL inside the secure file system (usually ./uploads/tx_aimeos/.secure/).
So I should store the download file into my secure upload folder?
Is there any rule that I have to consider? Like the naming or folder structure?
Can you tell me which of the following values should be filled for the import and where do I place the relativ download path?
array(
'attribute' => array(
0 => 'attribute.typeid',
1 => 'attribute.type',
2 => 'attribute.code',
3 => 'attribute.label',
4 => 'attribute.position',
5 => 'attribute.status',
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
PHP 7.4.30
Typo3 v11.5.21 LTS
There's not required nameing for the secure folder. We store md5 hashes like "a0...f9.jpg" so we are sure there's no potential security issue.
You should use:
- attribute.type = "download"
- attribute.code = "a0...f9.jpg"
- attribute.label = "myfile.jpg"
- attribute.position = 0
- attribute.status = 1
You should use:
That doesn't work because the download is stored as normal attribute instead of hidden attribute.
How can I import it as hidden attribute?
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
PHP 7.4.30
Typo3 v11.5.21 LTS
Add "product.list.type" => hidden to your mapping and your data:
https://aimeos.org/docs/Developers/Cont ... #Attribute
Perfect, that works.
Thank you!
Thank you!
Ubuntu 22.04.01
PHP 7.4.30
Typo3 v11.5.21 LTS
PHP 7.4.30
Typo3 v11.5.21 LTS
