Export Orders
tenkraD
Export Orders
Post by tenkraD » 23 Mar 2019, 11:22
Hi all,
im trying to Export Products & Orders with a scheduler Task.
So i setted up a scheduler task with jobs: Product Export and Orders Export CSV
Typoscript Configuration:
controller.jobs.product.export.location = /webroot/fileadmin/aimeos_product_csv/export
controller.jobs.product.export.standard.container.content = CSV   # CSV / PHPExcel
controller.jobs.order.export.csv.location = /webroot/fileadmin/aimeos_product_csv/export
controller.jobs.order.export.csv.container.content = CSV
For products it's working well, csv File is generated, but on Orders its doing nothing.
I dont get anny Error message on the scheduler task and i also dont get anny error message in aimeos log.
Do someone know what im missing?
Many thanks, tenkraD
Re: Export Orders
Post by aimeos » 25 Mar 2019, 12:40
The order CSV export doesn't export all orders by default but instead, on request. That means, if you tell Aimeos in the order panel of the admin interface that you want to export all orders or a slice of orders, then the CSV file will be generated by the job controller and you can download the file in the dashboard of the admin interface.
If you want to export all orders without manual interaction, you should write a service provider or decorator that does this for you.
