How can I change the number of items displayed?
I see that the default amount is 48. I've duplicated the extension (client-html) and am looking for where/what specifies it to be 48. I've seen -jsonapi has 48 and managed to update the number for the API, but can't find where to do it in the template.
Re: How can I change the number of items displayed?
Use this setting to change the number of product items in the main list:
https://aimeos.org/docs/Configuration/C ... lists/size
