Enable frontend login for customers
Dhara1510
Post by Dhara1510 » 03 May 2019, 10:06
Hello aimeos,
Thanks for your kind support for the issues I am facing.
I want the user to login first then place the order. Currently, the user can place an order as a guest user and also can create his account at the time of checkout.
How can I enable frontend login for user?
Dhara1510
Re: Enable frontend login for customers
Post by Dhara1510 » 03 May 2019, 10:24
I Got it. it takes default auth login for frontend users
