Incorrect URL path with multiple apache alias
Battamich
Post by Battamich » 03 May 2019, 11:24
Hi everyone,
I recently tried to install the aimeos demo inside my server running apache2. Inside this server I have multiple laravel installations and I tried to configure them like this inside my httpd.conf:
<VirtualHost *:80>
       ServerName {server_name}
       DocumentRoot /var/www/XXX/public
       Alias /XXY /var/www/XXY/public
       Alias /aimeos /var/www/aimeos/public
       <Directory /var/www/XXX>
              AllowOverride All
       </Directory>
       <Directory /var/www/XXY>
              AllowOverride All
       </Directory>
       <Directory /var/www/aimeos>
              AllowOverride All
       </Directory>
</VirtualHost>
I also modified my .htaccess file under public adding:
RewriteBase /aimeos
and APP_URL in .env file:
APP_URL={server_url}/aimeos
While both my other installations are working fine, both responding with correct routing:
{server_url}/XXX/products
{server_url}/XXY/products
Aimeos seems to responde correctly only when I try to get to the homepage {server_url}/aimeos/ redirecting me to {server_url}/aimeos/list.
All others routes responds like this: {server_url}/detail/15/Demo_article/0 removing my alias in the url and generating 404.
I can't understand the source of this problem.. is there any way to fix this?
Thanks in advance,
Michael
Re: Incorrect URL path with multiple apache alias
Post by aimeos » 03 May 2019, 15:51
Did you clear the cache (./artisan aimeos:cache)?
Does a direct call of {server_url}/aimeos/login work?
Battamich
Post by Battamich » 06 May 2019, 07:36
I cleared artisan cache using:
php artisan cache:clear
php artisan route:cache
php artisan config:cache
php artisan view:clear
The url {server_url}/aimeos/login works.
Even when I type {server_url}/aimeos/detail/15/Demo_article/0, I get the product page but I don't get redirected properly when I click the product itself from the list page.
Post by aimeos » 06 May 2019, 08:10
OK, that means basic routing is OK. Do other Laravel packages also show this behavior?
Battamich
Post by Battamich » 06 May 2019, 09:40
What do you mean by other Laravel packages? Do you mean other Laravel projects? If so, routing is working fine with the other projects.
Post by aimeos » 06 May 2019, 16:57
How does the generated URLs look like?
or with domain as absolute URL?
Battamich
Post by Battamich » 17 May 2019, 15:17
I'm not sure I understood your request completely..
What I want:
http://{myurl}/aimeos/detail/15/Demo_article/0
What I get:
http://{myurl}/detail/15/Demo_article/0
Trying to achieve that I also add inside /public/.htaccess the following:
RewriteBase /aimeos
As I did with the other ecommerce but it changed nothing.
