Oops, an error occurred! SQLSTATE[42S02]:
supremazy
Post by supremazy » 08 May 2019, 20:44
When i try to install aimeos with extension it gives "
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'typo3cms.mshop_locale_site' doesn't exist
" error.
I installed phpmyadmin but i dont now how am i do ?
Please help
Thank you.
Re: Oops, an error occurred! SQLSTATE[42S02]:
Post by aimeos » 09 May 2019, 09:02
For an unknown reason, the tables haven't been created automatically. Which TYPO3 and Aimeos version do you use?
To fix the problem, go to the extension manager and run the update script of the Aimeos extension.
supremazy
Post by supremazy » 09 May 2019, 16:24
Typo3 9.5.5
Aimeos 19.4.1
I ran update script but nothing is changed.
Post by aimeos » 10 May 2019, 08:27
Is there any error at the end of the update script?
