Design
Design
is it recommended to change frontend or backend design? Can I implement my own HTML template?
Re: Design
You can definitely use the bundled theme provided; no need to change if you like it.
If you want to create your own theme, you can start by reading the documentation https://aimeos.org/docs/Developers#Frontend and probably https://aimeos.org/docs/Laravel/Adapt_base_template.
Re: Design
Yes, you can change the frontend/backend design to match your requirements and you are encouraged to do so if you want.
