Make login require for checkout the order
Dhara1510
Post by Dhara1510 » 17 May 2019, 13:23
I want a user to login before checkout the order.
Current scenario: User can add product to cart and do checkout without login
Required scenario: User can add product to cart. User has to login when he want to do checkout. When user click on it should redirect user to login page.
How can it be done? Can you please guide me?
AnthonyLim
Re: Make login require for checkout the order
Post by AnthonyLim » 17 May 2019, 16:05
Not exactly what you ask for, but what I did was to make the user login even before shopping. It's pretty easy; just edit config/shop.php and configure the "routes" like so:
'routes' => [
      'default' => ['prefix' => 'shop', 'middleware' => ['web','auth']],
Dhara1510
Post by Dhara1510 » 20 May 2019, 05:59
Thanks. I have overridden routes and applied "auth" middleware to checkout controller and it works :)
