Create a $manager to get products details of a stored order!
I think it is a simple question. Everything is in the title : I'm still beginning with Aimeos and I would like to access all products details of a given stored order using my own controller.
I was hoping that retrieving the order details adding ['product'] domain in the criteria then access it with getProducts() was the correct way to do that but it wasn't.
Here is the code I used:
CODE: SELECT ALL
$obid = 1;
$context = app()->make('\Aimeos\Shop\Base\Context')->get();
$manager = \Aimeos\MShop\Factory::createManager( $context, 'order/base' );
$search->setConditions( $search->compare( '==', 'order.base.id', $obid ) );
$order = $manager->searchItems($search,['text', 'price', 'attribute', 'product']);
$order_products = $order[$obid]->getProducts();
$order is well set but $order_products is an empty array.
Using ->getProducts() is probably naïve
I probably misunderstood something, I couldn't find anything in the documentation and on this forum to help me.
I suppose too that using :
CODE: SELECT ALL
$obid = 1;
Re: Create a $manager to get products details of a stored or
Almost
If you want an order for a specific ID, easiest way is:
If you need to search for several orders:
$products = $manager->load($oid)->getProducts();
$orders = $manager->searchItems($manager->createSearch(),['order/base/product']);
foreach($orders as $order) {
$products = $order->getProducts();
