Error on homepage
Error on homepage
Hi, after I install the aimeos, I receive this error.
Anyone know the errors?
Environment : MAC using MAMP
- Screen Shot 2019-06-11 at 08.08.37.png (220.94 KiB) Viewed 1711 times
- using postman
- Screen Shot 2019-06-11 at 08.07.33.png (252.01 KiB) Viewed 1711 times
Re: Error on homepage
Guess you changed the configuration and this isn't a valid array any more:
https://github.com/aimeos/aimeos-larave ... op.php#L27
Hi aimeos, actually I just finish the fresh install by following the documentation on aimeos laravel github, haven't change any configuration, I saw also the line you said commented on my file. Any idea on that error?
Not yet. Can you add a
at
https://github.com/aimeos/aimeos-larave ... er.php#L87
and post the output from the console or Apache error log?
error_log( var_export( app( 'config' )->get( 'shop.page.catalog-stock' ) ) );
Hi aimeos, I already put the error log, but the output is empty. Any more idea?
- Screen Shot 2019-06-17 at 15.47.28.png (121.98 KiB) Viewed 1663 times
- Screen Shot 2019-06-17 at 15.45.56.png (103.1 KiB) Viewed 1663 times
Sorry, must be:
Without the "true", you won't get any output in the error log because it's directly written to the response.
error_log( var_export( app( 'config' )->get( 'shop.page.catalog-stock' ), true ) );
