Order Export Job
cnoelker
Order Export Job
Post by cnoelker » 11 Jun 2019, 14:59
Hi there,
using the latest Aimeos version in TYPO3 9.5, I configured the export location for the job order/export/csv .
I can start this and it does not return an error. However, it does create any file, either.
Another attempt, I started the download of orders in the orders module. This gave me the message that I would have to wait some minutes for the download. However, nothing happens here, either. Maybe it should create something like in this Twitter message? https://twitter.com/aimeos/status/89273 ... 44/photo/1
I currently have only one order, so the export shouldn't take that long. ;-)
Besides configuring the CSV location, I could not find much documentation for it. Maybe the export does not work because my order does not meet the requirement (=status?) for the export? How can I configure it?
Claudia
cnoelker
Re: Order Export Job
Post by cnoelker » 11 Jun 2019, 15:14
After some more waiting, the export-file actually appeared in the dashboard! So that riddle is solved.
How can I configure it's content?
And what is the order/export/csv job supposed to do?
Post by aimeos » 11 Jun 2019, 21:51
The order export is for exporting the orders you've filtered in the order panel of the admin interface (or all if you've used no filter). You can adapt the order export by configuring a different mapping:
https://github.com/aimeos/ai-controller ... se.php#L53
If you want an automatic export in a custom format, you should implement your own delivery service provider instead.
