PROBLEMS WITH LOADING PRODUCT IMAGES!!
williamgomes
Post by williamgomes » 19 Jun 2019, 00:50
hi there,
when trying to upload a product image I'm receiving the following error.
NoDecodeDelegateForThisImageFormat `JPEG' @ error/blob.c/BlobToImage/351, /html/typo3/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-
core/lib/mwlib/src/MW/Media/Image/Imagick.php:49
GFX/processor is ImageMagick
All TYPO3 image tests work fine
I migrated the system to a different server but did adapt all necessary paths correctly.
TYPO3 8.7.18
Aimeos 18.10.2
superscotty19
Re: PROBLEMS WITH LOADING PRODUCT IMAGES!!
Post by superscotty19 » 19 Jun 2019, 05:59
Hey,
It's just like PHP: even with the main module installed, you may still require extensions/modules. In this case, even though ImageMagick is installed, there's extra delegates required. Try this link:
https://github.com/thephpleague/glide/issues/237
HTH,
-Scott.
