Testing Aimeos extensions
Hi all,
I've set up a test environment like described here, but when I want to run ./vendor/bin/phing -Ddir=ext/myext testext, an error occurs:
What did I miss?
PHP Fatal error: Uncaught Error: Class 'Aimeos\MShop\Factory' not found in /var/www/test/aimeos-core/ext/myext/controller/frontend/tests/TestHelperFrontend.php:18
Stack trace:
#0 /var/www/test/aimeos-core/ext/myext/controller/frontend/tests/bootstrap.php(32): TestHelperFrontend::bootstrap()
Re: Testing Aimeos extensions
You are using a 2019.x core with a 2018.x extension.
Thank you. I feel kind of stupid now, but it works.
