How to use shop.php
How to use shop.php
I'm kishan. I am laravel developer and added your package in my project. please help me over shop.php how to use it and how it help me over any configuration in my site.
Thank You
Kishan Upadhyay
Thank You
Kishan Upadhyay
Re: How to use shop.php
You don't have to adapt the ./config/shop.php in a standard installation because the .env file already contains the database connection settings and the rest is configured with reasonable default. You will need to add settings if you want to adapt the HTML output or the admin interface for example or if you want to configure product import from files.
The best way to start is reading these articles: https://aimeos.org/docs/Laravel
