Laravel aimeos CMS
Laravel aimeos CMS
Hi to everyone!
I want to add the aimeos-laravel extension to a CMS (also built with laravel) but I'm having a lot of problems like the CMS trying to create the same tables as Aimeos and other stuff like that.
I don't want to use the TYPO3 extension or the Flow project.
Is there a way to handle this? Has anyone already done it?
Re: Laravel aimeos CMS
You mean the Laravel "users" table? Can you post what happens?
I tried with Voyager CMS (https://laravelvoyager.com/) but both projects has a "page" table.aimeos wrote:You mean the Laravel "users" table?
The result is a SQL error because the projects is trying to create a table that already exists.
OUTPUT:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'pages' already exists (SQL: create table `pages` (`id` int unsigned not null auto_increment primary key, `author_id` int not null, `title` varchar(255) not null, `excerpt` text null, `body` text null, `image` varchar(255) null, `slug` varchar(255) not null, `meta_description` text null, `meta_keywords` text null, `status` enum('ACTIVE', 'INACTIVE') not null default 'INACTIVE', `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
at /Users/luca/Desktop/voyageraimeos/vendor/laravel/framework/src/Illuminate/Database/Connection.php:664
660| // If an exception occurs when attempting to run a query, we'll format the error
661| // message to include the bindings with SQL, which will make this exception a
662| // lot more helpful to the developer instead of just the database's errors.
663| catch (Exception $e) {
> 664| throw new QueryException(
665| $query, $this->prepareBindings($bindings), $e
666| );
667| }
668|
Exception trace:
1 Doctrine\DBAL\Driver\PDOException::("SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'pages' already exists")
/Users/luca/Desktop/voyageraimeos/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:119
2 PDOException::("SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'pages' already exists")
/Users/luca/Desktop/voyageraimeos/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:117
That's an error of Voyager because Aimeos doesn't have a "page" table. All Aimeos tables are prefixed with "madmin_*", "mshop_*" and "users_*".
