[CLOSED] Replace template Aimeos 2019.07
lucadambros
Post by lucadambros » 05 Jul 2019, 09:27
I'm using Aimeos 2019.07 with Mac OS.
I'm trying to replace a partial template
 ext/ai-client-html/client/html/templates/catalog/detail/body-standard.php
In the old version, I created the same path in my extension:
 ext/my-ext/client/html/templates/catalog/detail/body-standard.php
and that worked but in the new version I am getting:
Template not available: client/html/templates/catalog/detail/seen-partial-standard.php
I don't want to recreate all the files related to the template. How do I solve this problem?
Also: why the navbar comes without the login/register buttons?
I installed aimeos 2019.07 from scratch
EDIT: SOLVED
if the old version is:
 $this->config( 'client/html/common/partials/selection', 'common/partials/selection-standard.php' ),
the new one will be:
 $this->config( 'client/html/common/partials/selection', 'common/partials/selection-standard' ),
You have just to remove ".PHP"
