[SOLVED] 2019.04 -> 2019.07 Upgrade tips ?
Re: 2019.04 -> 2019.07 Upgrade tips ?
Regarding the missing images: Seems like your aimeos.js file from the theme directory isn't up to date because the "src" and "srcset" attributes are not set when images are lazy loaded: https://github.com/aimeos/ai-client-htm ... os.js#L112
The Vue.js error in the admin interface is fixed in the new ai-admin-jqadm release. Please run "composer update"
