Emails : link to product detail leads to 404
Re: Emails : link to product detail leads to 404
The Laravel router is still buggy and uses arbitrary GET parameters for optional URL parameters. The URLs in the e-mails now contain the language to show the pages to the users in their language. To work around this, you should use "{locale}" as part of the shop routes (maybe also optional and at the end). Another option would be that we add an empty d_pos parameter as workaround.
Re: [SOLVED] Emails : link to product detail leads to 404
We've added empty default values for d_prodid and d_pos as workaround for Laravel so after updating, you should get:
But the URLs aren't nice. On the command line we don't really know if the additional parameters are required or not. Therefore, a new configuration setting exists which you can use to filter out those parameters you don't need:
Afterwards, you should have URLs like "baseurl/shop/Label" even in the e-mails. Can you confirm?
baseurl/shop/Label//?site=default&locale=fr¤cy=EUR
client/html/catalog/detail/url/filter => ['d_prodid', 'site', 'locale', 'currency']
To test the new code use:
composer req "aimeos/ai-client-html:2019.07.x-dev"
True, haven't thought about that and the code contains an array_flip() to be able to compare keys now.
