Regarding Authorize.net issue
BetaTest
Post by BetaTest » 03 Jul 2019, 10:20
Hello Aimeos,
I want to use cim method of authorize.net but unfortunately it does not come in omnipay payment gateways which you provide. It only shows three payment method in its dropdown
1. Authorize Aim
2. Authorize DPM
3. Authorize SIM
but i am unable to see authorize cim and i want to use authorize cim method for payment how to use that.
Please guide me
Regards
Deepak Sharma
Re: Regarding Authorize.net issue
Post by aimeos » 03 Jul 2019, 10:45
The Omnipay driver supports CIM already in it's latest version:
https://github.com/thephpleague/omnipay-authorizenet
You should add a AuthorizeCIM.php class that implements the necessary code:
https://github.com/aimeoscom/ai-payment ... er/Payment
kishanbupadhyaya
Post by kishanbupadhyaya » 05 Jul 2019, 09:08
@amieos,
How to make the Authorize.net CIM option to show up in the dropdown selection?
As i have seen aimeos documentation it supports only three authorize.net methods. There is no authorize.net CIM description
link https://aimeos.org/docs/User_Manual/Adm ... ze.net_AIM
Kindly share information about How to include Authorize.net CIM in my payment gateway.
Thank you
Post by aimeos » 05 Jul 2019, 12:23
@kishanbupadhyaya You should add a AuthorizeCIM.php class that implements the necessary code:
dsharma@taskme.biz
Post by dsharma@taskme.biz » 05 Jul 2019, 13:47
but @aimeos there is no authorise cim class. so how can i implement this class and kindly tell me steps to integrate it.
Link https://aimeos.org/docs/User_Manual/Adm ... ze.net_AIM
there is no instruction to integrate authorize.net cim method.
kindly tell us how to integrate it in our project.
Regards
Deepak Sharma
Post by aimeos » 06 Jul 2019, 11:26
You have to implement the class for CIM support yourself as it doesn't exist yet.
dsharma@taskme.biz
Post by dsharma@taskme.biz » 10 Jul 2019, 09:03
Hello Aimeos,
I have two questions -
Frontend
1.I have implemented Authorize.net CIM class successfully. When i submit form it gives me one error
The api username is invalid or not present what to do ?
Backend
1. Is this the correct way to set up authorize.net cim service in admin panel ?
Thankyou
Post by aimeos » 11 Jul 2019, 09:00
Seems like you don't pass the required values correctly to Authorize.net
