setup task
yong
Re: setup task
Post by yong » 17 Jul 2019, 10:19
And after that ...!? what about setup task ?
yong
Re: setup task
Post by yong » 17 Jul 2019, 10:21
I dit it ! But what's rhe next step please ? how can i write the setup tasks ?
Re: setup task
Post by aimeos » 17 Jul 2019, 10:22
You don't need a setup task because you
- don't migrate any data
- don't created a new domain
yong
Re: setup task
Post by yong » 17 Jul 2019, 10:25
thanks ! so after this i just have to execute php artisan aimeos:setup ?
Re: setup task
Post by aimeos » 17 Jul 2019, 10:27
yes
yong
Re: setup task
Post by yong » 17 Jul 2019, 10:49
I've this error
Re: setup task
Post by aimeos » 17 Jul 2019, 10:55
Make sure your extension depends on ai-laravel in the manifest.php file of your extension. Otherwise, the execution order is random.
yong
Re: setup task
Post by yong » 17 Jul 2019, 11:22
thanks ! how if i want to overwrite the setup that add some data and table in the users table (in fact i don't want to have the additional columns of the ai-laravel or other setup)
Re: setup task
Post by aimeos » 17 Jul 2019, 11:50
That doesn't work because Aimeos requires the address data in the users table. Otherwise, you would have to rewrite the Laravel customer manager too.
