Supplier - Item Name - Price on Separate Rows in CatalogList
Re: Supplier - Item Name - Price on Separate Rows in CatalogList
OK I've implemented your steps but still not seeing the brand. Specifically:
1.) Created brand attributes and assigned them to products
2.) TS->Setup now has:
3/4.) Modified products-standard.php ... Full disclosure: In the interest of getting a proof of concept as fast as possible, I modified like this:
... but the result is still the same - see attached - just shows media, then description, then price. Need media, then brand, then product/description, then price.
-S.
plugin.tx_aimeos.settings.client.html.catalog.lists.domains {
0 = media
1 = price
2 = text
3 = attribute
<div class="text-list">
<h2 itemprop="name"><?= $enc->html( $productItem->getName(), $enc::TRUST ); ?></h2>
<?php foreach( $productItem->getRefItems( 'text', 'short', 'default' ) as $textItem ) : ?>
<!-- /* Added by Scott 20190719 to show brand in FE catagloue list */ -->
<?php if( ( $attrItem = current( $productItem->getRefItems( 'attribute', 'brand', 'default' ) ) ) !== false ) : ?>
<?= $enc->html( $attrItem->getName() ) ?>
<?php endif ?>
<div class="text-item" itemprop="description">
<?= $enc->html( $textItem->getContent(), $enc::TRUST ); ?><br/>
</div>
<?php endforeach; ?>
</div>
-S.
- Screenshot_2019-06-29 Car Racks.png (22.84 KiB) Viewed 1472 times
Your code is correct. Can you show how you've assigned the attribute to the product? Is the attribute and type enabled?
Thanks for the confirmation. Product attribute assignment attached, as well as confirmation the Brand attribute is enabled
-S.
-S.
- Screenshot_2019-07-18-2 [TYPO3 CMS 8 7 4].png (21.73 KiB) Viewed 1471 times
- Screenshot_2019-07-18 [TYPO3 CMS 8 7 4].png (27.5 KiB) Viewed 1471 times
Types are case sensitive, so "Brand" and "brand" are different entities.
