How to add additional fields to a customer
mohal_04
Re: How to add additional fields to a customer
Post by mohal_04 » 12 Apr 2018, 09:38
aimeos wrote:No, it's the same as for the managers: You have to extend from the standard class and create e.g.
./ext/myextendsion/admin/jqadm/src/Admin/JQAdm/Product/Price/Mystandard.php
which contains:
class MyStandard extends Standard
    protected function fromArray( \Aimeos\MShop\Product\Item\Iface $item, array $data )
        // your modified code
and configure your new class using:
admin/jqadm/product/price/name = Mystandard
e.g. for Laravel in config/shop.php:
'admin' => [
    'jqadm' => [
        'product' => [
            'price' => [
                'name' => 'Mystandard'
Thanks Sir!!! Your help is too much appreciated. I have resolved the issue with your help. I wonder why I didn't have to overwrite fromArray() method from Standard class when I was adding custom field in Basic tab.
Thanks!
Umer
Post by aimeos » 12 Apr 2018, 11:27
Because it uses fromArray() of the item without any special handling. We will try to use that in the subpanel classes too if possible in the next version.
mohal_04
Post by mohal_04 » 12 Apr 2018, 11:38
aimeos wrote:Because it uses fromArray() of the item without any special handling. We will try to use that in the subpanel classes too if possible in the next version.
OK thanks for all the help!!! :) :) :) :) :)
MikaelNazarenko
Expert
Post by MikaelNazarenko » 22 Jul 2019, 12:51
Hello everybody!
I am extending customer. Seems everything is clear. But can anybody, please, tell me if I can find somewhere the example of
./ext/myextension/lib/custom/config/mshop.php
exactly for the Customer ? I think it must exists somewhere in Aimeos core. Because there is complex query for search and other. I would like to take a look at original and then extend it.
My config file looks like:
<?php
return [
    'customer' => [
        'manager' => [
            'name' => 'Customer',
            'standard' => [
                'delete' => array(
                    'ansi' => '
					DELETE FROM "users"
					WHERE :cond
                'insert' => array(
                    'ansi' => '
					INSERT INTO "users" (
						"siteid", "name", "email", "company", "vatid", "salutation", "title",
						"firstname", "lastname", "address1", "address2", "address3",
						"postal", "city", "state", "countryid", "langid", "telephone",
						"telefax", "website", "longitude", "latitude",
						"birthday", "status", "vdate", "password",
						"updated_at", "editor", "created_at"
					) VALUES (
                'update' => array(
                    'ansi' => '
					UPDATE "users"
					SET "siteid" = ?, "name" = ?, "email" = ?, "company" = ?, "vatid" = ?,
						"salutation" = ?, "title" = ?, "firstname" = ?, "lastname" = ?,
						"address1" = ?, "address2" = ?, "address3" = ?, "postal" = ?,
						"city" = ?, "state" = ?, "countryid" = ?, "langid" = ?,
						"telephone" = ?, "telefax" = ?, "website" = ?,
						"longitude" = ?, "latitude" = ?, "birthday" = ?,
						"status" = ?, "vdate" = ?, "password" = ?, "updated_at" = ?, "editor" = ?
					WHERE "id" = ?
                'search' => array(
                    'ansi' => '
					SELECT lvu."id" AS "customer.id", lvu."siteid" AS "customer.siteid",
						lvu."name" AS "customer.label", lvu."email" AS "customer.code",
						lvu."company" AS "customer.company", lvu."vatid" AS "customer.vatid",
						lvu."salutation" AS "customer.salutation", lvu."title" AS "customer.title",
						lvu."firstname" AS "customer.firstname", lvu."lastname" AS "customer.lastname",
						lvu."address1" AS "customer.address1", lvu."address2" AS "customer.address2",
						lvu."address3" AS "customer.address3", lvu."postal" AS "customer.postal",
						lvu."city" AS "customer.city", lvu."state" AS "customer.state",
						lvu."countryid" AS "customer.countryid", lvu."langid" AS "customer.languageid",
						lvu."telephone" AS "customer.telephone",lvu."telefax" AS "customer.telefax",
						lvu."email" AS "customer.email", lvu."website" AS "customer.website",
						lvu."longitude" AS "customer.longitude", lvu."latitude" AS "customer.latitude",
						lvu."birthday" AS "customer.birthday", lvu."status" AS "customer.status",
						lvu."vdate" AS "customer.dateverified", lvu."password" AS "customer.password",
						lvu."created_at" AS "customer.ctime", lvu."updated_at" AS "customer.mtime",
						lvu."editor" AS "customer.editor"
					FROM "users" AS lvu
					:joins
					WHERE :cond
					GROUP BY lvu."id", lvu."siteid", lvu."name", lvu."company", lvu."vatid",
						lvu."salutation", lvu."title", lvu."firstname", lvu."lastname",
						lvu."address1", lvu."address2", lvu."address3", lvu."postal",
						lvu."city", lvu."state", lvu."countryid", lvu."langid",
						lvu."telephone", lvu."telefax", lvu."email", lvu."website",
						lvu."longitude", lvu."latitude", lvu."birthday", lvu."status",
						lvu."vdate", lvu."password", lvu."created_at", lvu."updated_at",
						lvu."editor"
					/*-orderby*/ ORDER BY :order /*orderby-*/
					LIMIT :size OFFSET :start
                'count' => array(
                    'ansi' => '
					SELECT COUNT(*) AS "count"
					FROM (
						SELECT DISTINCT lvu."id"
						FROM "users" AS lvu
						:joins
						WHERE :cond
						LIMIT 10000 OFFSET 0
					) AS list
                'newid' => array(
                    'db2' => 'SELECT IDENTITY_VAL_LOCAL()',
                    'mysql' => 'SELECT LAST_INSERT_ID()',
                    'oracle' => 'SELECT users.CURRVAL FROM DUAL',
                    'pgsql' => 'SELECT lastval()',
                    'sqlite' => 'SELECT last_insert_rowid()',
                    'sqlsrv' => 'SELECT SCOPE_IDENTITY()',
                    'sqlanywhere' => 'SELECT @@IDENTITY',
But then I am not able to log in into admin panel.( Something wrong (
Thank you !
Post by aimeos » 22 Jul 2019, 13:00
Please have a look here for the core customer config file:
https://github.com/aimeos/aimeos-core/b ... stomer.php
For Laravel it's here:
https://github.com/aimeos/ai-laravel/bl ... stomer.php
MikaelNazarenko
Expert
Post by MikaelNazarenko » 22 Jul 2019, 13:04
Thank you, buddy!
But as I understand exactly for customer I only need this:
'laravel' => array(
            'delete' => array(
                'ansi' => '
					DELETE FROM "users"
					WHERE :cond
            'insert' => array(
                'ansi' => '
					) VALUES (
            'update' => array(
                'ansi' => '
					UPDATE "users"
					WHERE "id" = ?
            'search' => array(
                'ansi' => '
					FROM "users" AS lvu
					:joins
					WHERE :cond
						lvu."editor"
            'count' => array(
                'ansi' => '
					FROM (
						FROM "users" AS lvu
						:joins
						WHERE :cond
					) AS list
            'newid' => array(
'address', 'lists' and other I may skip ? Will they loaded from default ?
Post by aimeos » 22 Jul 2019, 13:06
yes
MikaelNazarenko
Expert
Post by MikaelNazarenko » 22 Jul 2019, 14:47
Laravel Framework 5.8.26
aimeos-laravel 2019.04
The topic is named as 'How to add additional fields to a customer' but here is no explained exactly about customer ((
Thank for guy who explained for Product but it doesn't help me completely (
Maybe somebody may explain me where I am wrong ? Regarding aimeos version 2019.04. Because now I can't access the admin panel, I get '403 This action is unauthorized.' and seems it takes a lot of time to find the problem ((( :(
My files:
/var/www/labor/ext/labor/lib/custom/setup/default/schema/customer.php
<?php
 * @copyright Aimeos (aimeos.org), 2016-2018-2018
return array(
    'table' => array(
        'mshop_customer' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
            $table = $schema->getTable( 'mshop_customer' );
            $table->addColumn( 'name1', 'string', array( 'length' => 255 ) );
            return $schema;
/var/www/labor/ext/labor/config/mshop.php
<?php
return array(
    'customer' => array(
        'manager' => array(
            'standard' => [
                'delete' => array(
                    'ansi' => '
					DELETE FROM "users"
					WHERE :cond
                'insert' => array(
                    'ansi' => '
					) VALUES (
                'update' => array(
                    'ansi' => '
					UPDATE "users"
					WHERE "id" = ?
                'search' => array(
                    'ansi' => '
						lvu."editor" AS "customer.editor", lvu."name1" AS "customer.name1"
					FROM "users" AS lvu
					:joins
					WHERE :cond
						lvu."editor"
                'count' => array(
                    'ansi' => '
					FROM (
						FROM "users" AS lvu
						:joins
						WHERE :cond
					) AS list
                'newid' => array(
/var/www/labor/ext/labor/lib/custom/src/MShop/Customer/Manager/Customer.php
<?php
namespace Aimeos\MShop\Customer\Manager;
class Customer extends Standard
    private $salt;
    private $searchConfig = array(
        'customer.name1'=> array(
            'code'=>'customer.name1',
            'internalcode'=>'mpro."name1"',
            'label'=>'Name 1',
            'type'=> 'string', // integer, float, etc.
            'internaltype'=> \Aimeos\MW\DB\Statement\Base::PARAM_STR, // _INT, _FLOAT, etc.
    public function __construct(\Aimeos\MShop\Context\Item\Iface $context)
        parent::__construct($context);
        /** mshop/customer/manager/salt
         * Password salt for all customer passwords of the installation
         * The default password salt is used if no user-specific salt can be
         * stored in the database along with the user data. It's highly recommended
         * to set the salt to a random string of at least eight chars using
         * characters, digits and special characters
         * @param string Installation wide password salt
         * @since 2014.03
         * @category Developer
         * @category User
         * @see mshop/customer/manager/password/name
         * @sse mshop/customer/manager/password/options
        $this->salt = $context->getConfig()->get( 'mshop/customer/manager/salt', 'mshop' );
    public function saveItem( \Aimeos\MShop\Common\Item\Iface $item, $fetch = true )
        die;
        // a modified copy of the code from the parent class
        // extended by a bind() call and updated bind positions (first parameter)
     * @param bool $withsub
     * @return \Aimeos\MW\Criteria\Attribute\Iface
     * @throws \Aimeos\MW\Common\Exception
    public function getSearchAttributes( $withsub = true )
        $list = parent::getSearchAttributes( $withsub );
        foreach( $this->searchConfig as $key => $fields ) {
            $list[$key] = new \Aimeos\MW\Criteria\Attribute\Standard( $fields );
        return $list;
     * @param array $values
     * @param array $listItems
     * @param array $refItems
     * @param array $addrItems
     * @param array $propItems
     * @return \Aimeos\MShop\Customer\Item\Customer|\Aimeos\MShop\Customer\Item\Iface
     * @throws \Aimeos\MShop\Exception
    protected function createItemBase(array $values = [], array $listItems = [], array $refItems = [], array $addrItems = [], array $propItems = [])
        $helper = $this->getPasswordHelper();
        $address = new \Aimeos\MShop\Common\Item\Address\Simple( 'customer.', $values );
        return new \Aimeos\MShop\Customer\Item\Customer(
            $address, $values, $listItems, $refItems, $addrItems, $propItems, $helper, $this->salt
/var/www/labor/ext/labor/lib/custom/src/MShop/Customer/Item/Customer.php
<?php
namespace Aimeos\MShop\Customer\Item;
    protected $name1;
    public function __construct(\Aimeos\MShop\Common\Item\Address\Iface $address, array $values = [], $listItems = [], $refItems = [], $addrItems = [], $propItems = [],
                                ?\Aimeos\MShop\Common\Helper\Password\Iface $helper = null, ?string $salt = null)
        parent::__construct($address, $values, $listItems, $refItems, $addrItems, $propItems, $helper, $salt);
    public function fromArray( array &$list, $private = false )
        $unknown = [];
        $list = parent::fromArray( $list );
//        foreach( $list as $key => $value )
//            switch( $key )
//                case 'myid': $this->setMyId( $value ); break;
//                default: $unknown[$key] = $value;
        return $list;
//        return $unknown;
    public function toArray( $private = false )
        $list = parent::toArray( $private );
        return $list;
        if( $private === true ) {
            $list['myid'] = $this->getMyId();
        return $list;
I think problem in this file /var/www/labor/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Controller/AdminController.php
		if( Auth::check() === false
			|| $request->user()->can( 'admin', [AdminController::class, ['admin', 'editor']] ) === false
			return redirect()->guest( 'login' );
But I am really logged in ( in front-end part it works. Please help me (
Also createItemBase method is not called
I noticed, the following condition is triggered:
So user has not permissions for some reason ( Maybe groups data were not fetched..
Post by aimeos » 22 Jul 2019, 20:44
Authentication checks in Laravel are done in that class and it uses the customer/group manager to get the data:
https://github.com/aimeos/aimeos-larave ... upport.php
You posted code contains some bugs but I haven't seen a real blocker but maybe there's a PHP error that prevents your class from working. Did you check your error log if something goes wrong?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 22 Jul 2019, 20:54
Yes sure there are bugs, but behavior is strange.. (( I checked all logs, I have configured PHP to log all warnings and everything, no any errors anywhere..( I have tried different variants but the same behavior, if I try to visit /admin - it redirects me to /home.. ( if I delete this file /var/www/labor/ext/labor/config/mshop.php of course it works(( I am crying ((
