Locating components / templates
GalinaBublik
Re: Locating components / templates
Post by GalinaBublik » 28 Nov 2017, 08:30
Clean cache, cookies and other data of browser. This not help. Opened my project in else browser.
I still see symshop\ext\ai-client-html\client\html\templates\basket\mini\body-default.php
Can i rewrite this template?
Post by aimeos » 28 Nov 2017, 22:12
Copied "./ext/ai-client-html/client/html/templates/basket/mini/body-default.php" to "./ext/aitest/client/html/templates/basket/mini/body-default.php" (extension generated by https://aimeos.org/developer/extensions/), added "TEST" in the template before "<section class=" and it worked out of the box (new session without cookies).
Can you post your Aimeos configuration you've added to the config*.yml files?
Please also post the output of "composer show".
eh3an2010
Post by eh3an2010 » 21 Apr 2018, 05:07
Caching is enabled by default as long as you don't disable it during development. Add this to your ./app/config/config.yml (four spaces per level) to disable caching
my blog: طراحی سایت
elsneraustralias
Post by elsneraustralias » 30 Jul 2019, 07:42
Hello, Yes you can remove the session cookie form your browser. :?:
